Using Automated Test Tools (QA) with LabVIEW
Vaishnavinatarajan,
The thread above mentions several options for automated software testing. I am just requoting some below... hope this helps:
A software product we offer called TestStand.  The overview of this is below:
NI TestStand is a ready-to-run test management environment designed to accelerate the development of your test and validation systems. NI TestStand is used to develop, manage and execute test sequences. These sequences integrate test modules written in any test programming language. Sequences also specify execution flow, reporting, database logging and connectivity to other enterprise systems.
As the overview mentions, you can use any test programming language in your sequences, so incorporating LabVIEW files into a test sequence is simple.
I hope this helps, but let me know if you have any quesions.
Chris R.
" The NI LabVIEW Unit Test Framework Toolkit may provide the functionality you are looking for.  I've attached links below to the product page for the toolkit, a white paper describing the toolkit, and a webcast demonstrating it as well.  Hopefully this helps point you in the right direction!
Prove It Works:  Using the Unit Test Framework for Software Testing and Validation
https://www.ni.com/en/support/documentation/supplemental/09/using-the-unit-test-framework-for-softwa...
Josh B
Tanim
Message 11 of 11
(867 Views)
