Using Acrobat ActiveX methods
I have successfully inserted an Acrboat container and opened the correct file, but in a effort to set a few parameters I have gotten an unsatisfactory view.
I have successfully set the toolbars and scrollbars to be off.
I have successfully set the page to be displayed.
However I would only like one page to show and I would like for that page to fill (zoom to) the container window.
So far it zooms out to show 3 to 4 pages at a time.
Doug Ferguson
(2,790 Views)
Hi Doug,
Not sure if this will do it as I haven't worked with Acrobat ActiveX a lot, but the viewMode constant in your code is "PDFullScreen".  Have you tried "PDFFullScreen"?
Dave C.
(2,763 Views)
Well, that would make a difference.  Smiley Surprised
However, I have replaced the PDF container with the Web Browser container. Its much cleaner and turns out to be a better solution.
Doug Ferguson
(2,741 Views)
