Using APT ActiveX methods to create a labview program for BPC 203 3 channel Benchtop Piezo controller
Hi Everyone,
                  I am really very new to Labview and i am in great need for some help.I am assigned a task where i am supposed to create a labview program to control or moniter a BPC203 3 channel benchtop  Piezo controller. I created a program with the help of the instructions provided in the APT-Labview guide provided by Thorlabs.But th program doesnt run . Whenever i try to run it i get the same error which says that "Control HW Communications disabled".I have attached a snapshot of the error message.So i tried to create a small program in labview which would read the volage output.Even there i got the same error message.I suppose there is some mistake on my part which i am not able to correct due to the lack of proper knowledge.Could anyone please help me to solve this problem.A slight elaboration would be highly appreciated.Also i think the error lies in the use of invoke node with the get Voltage output method. I am not sure whether the parameters i have provided to the invoke node are correct.Any help of any sort would be highly appreciated.
(3,821 Views)
Hi
I had the same problem today. However, I noticed that the piezo controller has 3 channels with separate slots and they are packaged in the same box. Therefore the whole box has a serial number, probably something like 71822280, and this is written with large letter. Now, in order to communicate with any of the channels, this does not help, but one needs to communicate directly with the interested channel and they have thier OWN SERIAL NUMBERS.
For example channel 1 (my X direction in the nanoMax stage) has serial 91822281, Y has 91822282 and Z has 91822283. So try looking if you have the right serial number 🙂 Hopefully you found out this yourself but this might help others, I took me3 hours to get this thing working when I started to plug-in the cables and everything.
Lasse
(3,672 Views)
