Using 4 wire PT1000 with NI 9219
I am using PT1000 on my NI9219 hardware to collect temperature data using DAQmx.
I have created a one seperate task for taking inputs of T1 and T2. When I run the task, It is showing temperature values. But when I create a simple program for this, values are not at all dispying. What will be the possible reasons?
Message 1 of 10
(2,629 Views)
Hi Aditi,
So the reason will be within that "simple program" which you created, but failed to attach!
Message 2 of 10
(2,625 Views)
Sorry, I forgot to attached..
Here I have attached both my programs,
1.  for t1 temp input (test)
2. with t1, t2 and flow meter (Analog input)
Message 3 of 10
(2,611 Views)
Accepted by topic author Aditi.hiray
Run the program with highlight execution and see step by step  where the error is happening.
Message 4 of 10
(2,605 Views)
Thanks for suggesting me highlight execution method.
I am getting following errors:
 200077 (Read mx) although I have specified my channels.
200072 (Create a channel) If I select my temperature task in 'task in'
Since I am new in Labview programming, correct me if I am doing anything wrong.
I appreciate your help 🙂
Message 5 of 10
(2,493 Views)
Hi Aditi,
Did you read the error explanations?
-200077: unsupported value of the property
-200072: duplicate channels in task not supported
Do you correctly setup the DAQmx task?
Which DAQmxRead gives the error?
Why do you select a task when you explicitely wire channels to the CreateChannel function?
Message 6 of 10
(2,480 Views)
Thanks for your reply!
Yes I did setup the task correctly.
For t1 temp I have assigned a0 port and for t2 temp a1 port.
But the thing I did is, I have assigned one task for different programs, is that generating any error?
Message 7 of 10
(2,476 Views)
Hi Aditi,
Do you run those "different programs" in parallel? That might be the source of your problems…
A DAQmx task is a resource which can only be run/actively used once at a time!
Message 8 of 10
(2,473 Views)
No I don't!
Till sample clock, it is running ok. but once signal leaves from read mx 'error 200077' occurs which is
Requested value is not a supported value for this property. The property value may be invalid because it conflicts with another property.
Message 9 of 10
(2,469 Views)
Is this happening because of lack of any specific library? which libraries do I need to install exactly?
Message 10 of 10
(2,382 Views)
