Username informaion in UNC
I am trying to create a file on a network share using the UNC path;
\\Computer\Share
Login information is required to access this share.  I can make it work by storing the password in windows, but I would rather store the login information in the VI.
Is there a way to store the username & password inside the VI, or do I have to do this in windows?
Thank you
(3,047 Views)
You could use the command "net share"  to connect and disconnect the network share. The login name and password are parameters of the command.
System exec.vi can be used to call the command.
André (CLA, CLED)
(3,040 Views)
