User interface on different resolution monitor
I did select VI Properites--> window size --> Maintain proportions ... and Scale all objects,
But I think the problem is the fonts size is fixed, so even before I build executabe file, I resize the VI window, I will see the objects are all messed up (see attachment)
This should be a pretty common problem. Anybody know a solution?
DG
(2,769 Views)
As far as I know this is caused by different types. I had a similar problem. And I couldn't solve it. And there were only controls (buttons and numbers), no graphs or anything else. And I guess there is the problem because the font size of labeled buttons are not resized the same way the other controls are.
(2,747 Views)
Greetings!
   Which version of LabVIEW are you using? I tested the same with LabVIEW 8.2 with the VI properties to scale enabled and maintain proportions enabled. I was able to make an executable of the following VI and tried modifying the windows size and it resized accordingly. I also moved it to a lower resolution monitor and played with the window size and did not notice the behavior.
If you are using LabVIEW 8.2, can you please post a simple application and mention the steps with which you were able to reproduce the issue with LabVIEW 8.2. We would most appreciate that.
Thanks much and hope this helps
Best regards
Avi Harjani
(2,715 Views)
