User interface doesn't auto scale for different window size after installing exe file
My team has made a real-time vibration measurement system and then installed it in another PC (not having LabVIEW) from exe file. The issue is that the user interface window doesn't autoscale according to the user desktop size. We have to use it for the smaller desktop as well as the larger screen size. It should fit automatically to the available screen size. Is there any specific method of doing that?
(1,795 Views)
On your main VI, as well as any other VIs that show their front panel, have you tried toggling the check boxes on the "Window Size" page in their "VI Properties" window?
(1,777 Views)
I don't know the answer but to say this has always been a serious issues with LabVIEW applications requiring all kinds of "work arounds" to maintain proper scaling at any monitor resolution other than the one it was designed at.
Sure you can check the "Maintain proportions of window for different monitor resolutions", good luck with that.
I have long slice given up on even trying to make my applications work on any monitor. If they are not designed to run full screen 1200x1600 (our most common monitor resolution) then the window size is fixed and that's all you get.
=== Engineer Ambiguously ===
(1,751 Views)
