User action recorder
I search a VI which records all the controls pressed by a user on a front panel and which can be played back without the need to press again the controls.
Thank you by advance for your help.
Best Regards.
(2,949 Views)
Correct the sentence "I Search" "I am searching".
There is no such ready made solution available but yes you can download AutoIT tool and call AutoIT ActiveX in LabVIEW and you can achieve your target.
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
(2,921 Views)
Accepted by topic author laurym
Here's something that records the sequence of Booleans and one String.  Run it, hit any sequence of buttons, change the text in the String control, then hit Stop.  The buttons and String control will replay the changes in the sequence you entered.  You can add a timestamp to the cluster and replay with the same timing, too.  This is just a quick demo; you can do a lot more.  The key is in the event structure, just add to the events that the visible frame handles to add more controls to record.
Jim
(2,905 Views)
