User Interface Delay Problem
I use LabVIEW 2010 and develop a DAQ system. For real time monitoring I use graphics in fact mixed signal graph. As you see in the code I need to refresh the graphics in a time period. However, the cursors on the screen naturally delays also. anyone has a smart solution for this problem ?
"You live in a graphical world. Why not program in one?"
(2,893 Views)
Hi veli,
use parallel loops, one for DAQ and one for all cursor stuff. The second loop may run faster or even use an event structure (to minimize CPU usage)...
- Use UnbundleByName for getting the cursor properties, it's much more readable...
- You can enlarge the IndexArray function to show more than one output...
- The FOR loop on the upper right does the same as a simple ArraySubset function...
- Comparing floats for equality may become a problem...
- Is there a reason to use a MixedSignalGraph instead of an XYGraph?
(2,882 Views)
Thanks for suggestions. I will follow them.  I was going to use Mixed Signal Graph for plotting some group of plots. But I will use single group in another tabs now.
(2,828 Views)
