User Interacting
I have modified it a bit. Have a look.
Also if your problem is solved then you should mark solution.
Also Kudo(s) will be appreciated. Smiley Wink
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 11 of 17
(984 Views)
S I seen your reply. I want to perform my machine vision program continuously if the model is once selected. Where do I need to place my machine vision vi in your vi give any ideas.
Silver_Shaper | CLD
Message 12 of 17
(979 Views)
As its a state diagram, once you select your model, you know it goes in indication state.
There you can show indication whatever you want, and instead of going back to no event state, you can add one more state called say "Process"
where you will have your Machine vision vi.
Once that vi stops executing then go back to no event state.
Let me know if you understand this.
Gaurav k
CLD Certified !!!!!
Message 13 of 17
(975 Views)
Sorry am realy not understand. can u show me in example by adding a random number generator to generate number continusly once model is selected.
Silver_Shaper | CLD
Message 14 of 17
(972 Views)
You should study about state diagram architecture. Search on ni site you will find information about it.
Gaurav k
CLD Certified !!!!!
Message 15 of 17
(966 Views)
Thanks for your reply gaurav.. Problem Solved.S i need to learn lot more in labview i just started a month back only. Any how thanks again.
Silver_Shaper | CLD
Message 16 of 17
(961 Views)
Accepted by topic author Silver_Shaper
Do not forget to mark solution.
Best of Luck . Smiley Wink
Gaurav k
CLD Certified !!!!!
Message 17 of 17
(956 Views)
