User Input State Machine does not work as expected - unsure what to do
You could use the Value(Signaling) property for each control inside of the cluster.  You can just write the current value (or a default value).  This would queue up a Value Changed event for each of those controls, forcing the check to be done.
@ijustlovemath wrote:
Also, why can't references be included in subVIs (from the Edit - create subvi menu)?
Where would the subVI know where that is a reference to?  You have to pass the references into subVIs.
Message 11 of 11
(692 Views)
