User Dialog in a sub VI not showing up in Main VI
I have a sub VI that runs correctly.  It has various User Interfafe windows.  These windows are not popping up when the sub VI is called from a main VI.  What did I miss?
Michael C. Nedrow
(2,757 Views)
Did you look at the sub-vi properties, and choose "show front panel when called"?
pic
Message Edited by vt92 on 03-06-2009 05:01 PM
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(2,750 Views)
Thank You;
The settings that you mentioned were / are correct.  I figured it out just before I saw your post, I meant write and inform everyone that I found my error.  Talk about a forehead slapper!!!
I had changed out one of my pieces of test equipment, and did not reste the GPIB address.
Thanks Again
Mike
Michael C. Nedrow
(2,717 Views)
