Use the system exec.vi to invoke the DOS command
Use the system exec.vi to invoke the DOS command. It is normal to use the source program, but when EXE is delayed by 8S, the CMD window will be popped up.
(3,049 Views)
Individuals have three opinions, but they do not know how to verify them.
1, the lack of part of the program running environment
2, computer access to CMD is insufficient.
3. The way to generate EXE is not right.
Cat TongueCat TongueCat TongueCat TongueCat Tongue
(3,046 Views)
Try the command string in a cmd window and you'll see it doesn't work. Just Calling on a .txt will have no effect. If you want it to open in text editor you can e.g. use "start filename.txt"
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,014 Views)
The source program is achievable.I mainly want to study why the source program and exe are different, which is very important to me.
(3,004 Views)
I'm guessing this is related to your other topic, so I will post the link for reference.
Bill
CLD
(Mid-Level minion.)
(2,998 Views)
Okay, thank you
(2,981 Views)
