Use the built-in PID vi to regulate the timing of a solenoid valve
Hi, I'm trying to create a cooling system for a box using a solenoid valve. The valve is only able to open and close, and I'd like to implement a PID control to regulate the amount of time it's open for based on the current temperature of the box.
I'm using LabVIEW 2010, and I have the PID and fuzzy logic toolkit, but I have very little experience with LabVIEW or PID controls.  The built in PID.vi has 2 output branches, "output" and "dt (out)", but I don't understand exactly what those are, or what I should be wiring them to. If anyone could give me a basic overview of the steps I'll need to take to set up the system, it would be very very much appreciated!
(2,776 Views)
Have you searched this forum already?  You are looking to couple the PID output with a PWM (Pulse Width Modulation) generator, which will cycle your valve on and off.  If the board controlling the valve has a built-in timer output, you can do PWM in hardware.  If not, you can do it in software as demonstrated here.
I wrote up a long explanation of the PID VI here (spread across many messages), but there are many other good examples already posted on this forum as well.
(2,767 Views)
Ok wonderful, I'll look at those, thank you so much! I had searched the forum, but I didn't really know what I was looking for so I found it somewhat overwhelming.
(2,750 Views)
