Use of LabVIEW6.2 runtime
My problem is the use of LabVIEW files, programmed with LabVIEW6.1. These files should be transferred to another PC and should run with a LabVIEW runtime version.
Is it necessary to create .exe files to run them? Standart LabVIEW-files can't be run on the System.
Thanks a lot
(2,788 Views)
Sorry, I thought of LabVIEW6.1
(2,788 Views)
Yes you have to build a Exe from your VIs. For this you need the FDS + Application Builder or the PDS Version of LabVIEW.
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,788 Views)
Thanks, I hoped I was wrong.
(2,788 Views)
