Use of Integration VI
I want to use the basic integration VI .
However I don't have a formula for the input, I have an X and Y one dimensional arrays,
 How could I use this VI with just the one dimensional arrays rather than a formula?
Message 1 of 25
(685 Views)
Do you have evenly spaced data points? If so, use Mathematics >> Integ & Diff >> Integral x(t) #
It is in vi.lib\Analysis\2dsp.llb\Integral x(t).vi
Message 2 of 25
(671 Views)
Try attached implementation of trapezoid rule.
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
Message 3 of 25
(621 Views)
Your two input arrays differ in size so integration will fail. Can you attach a VI with clean data?
What is the output you want?
Message 4 of 25
(600 Views)
Once you clean up your data such that both arrays have equal length and x is sorted and does not contain duplicates, here's what you could do.
(Sorry, I originally had x and y reversed. I reattach a corrected version. Why would they call the lower input "T" instead of "X"????)
Message 5 of 25
(596 Views)
Integration should not need duplicate time values removed. Yes, I understand that the recommended palette VIs could return an error, but that seems to be an unnecessary restriction.
The following data is easily integrated by hand, and should be supported by the integration VIs:
**Update** Uneven Numeric Integration VI allows for duplicate time values. It only returns an error if sorting changes the order and there's one or more duplicates in T
Doug
Message 6 of 25
(577 Views)
Hmmm,... So what would the integral be for the following data where the same X has multiple different Y values? I guess the result would depend on the order of the duplicates.
T, X
1, 5
2, 6
3, 8
3, 1000
3,-20
4, 80
5, 100
(Yes, I originally had the inputs swapped and got the duplicate error)
Message 7 of 25
(567 Views)
I need a graph of the running interval for all points
Message 8 of 25
(484 Views)
Thank you everybody for what you've given me so far
Message 9 of 25
(483 Views)
... so, is your problem solved or do you still have questions?
Message 10 of 25
(464 Views)
