Use Text Ring to Set Parameter; Need Reverse Text Ring to Read?
If you are just looking for the multiplier, just set that as the value for the ring.  Attached is a custom control I quickly made.  You can see that it is a ring control of type Double.  So the user will see "10uV", but the value attached to that string is 10e-6.  You can add more to the ring if you need to.
EDIT:  Just reread the whole thread.  It looks like Jeff has the solution you need.
GCentral
Message 11 of 12
(334 Views)
Waiting for my test to get done so I'm playing around, please don't mind me here.  I made a little vi for you that converts your Sensitivity commands into a voltage, shows it in text (using crossrulz's control - which, as he mentioned, needs to be completed for the whole range), and then reverses the voltage back into sensitivity command...
(Original poster has spent quite a bit of time in putting together all those case structures in his original VI so just showing yet another alternate way of doing it.)
-DP
New Controls & Indicators made using vector graphics & animations? Click below for Pebbles UI
Message 12 of 12
(318 Views)
