Use Event Structure in 2 different VI
I am new in LabView, I have got tne following question:
I have 2 different VI, a user event (change boolean state) occurs in the 1st VI, my goal is an event structure in the 2nd VI reacts to the event. I tried a static and also dynamic event configuration. Result: the event structure of 2nd VI never reacts.
Idea to help me?
Thank you!
PB
(2,655 Views)
You need to create a reference of the boolean in the first vi, and use that reference in the second vi. Then the event structure will see the actual change in the first vi. There are some Labview examples on using references.
- tbob
Inventor of the WORM Global
(2,641 Views)
