Use 4QAM and 8PSK to alternately modulate and demodulate a section of signal
Hi!I just started using labview. I modulate the first half of a signal with 4QAM, and the second half with 8PSK. After adding the mapping results in RFSG mode, I filter and transmit. How should the RFSA side demodulate the received signal separately? How to splice this signal at the receiving end?
(1,868 Views)
(1,826 Views)
