Usage of timer in Labview
I had posted this question in the counter/timer board but did not get a single answer. I am trying here again.
Please explain how do I use a timer function in LabView 8.0 so that I can write a digital value to my PCI-6602 DAQ card every few minutes.
For example, it should write the first value at 00:01:00, the second value at 00:15:00 and so on. This is according to a test sequence file which is attached.
Moreover, should the software timer function of labview be used or is there any such hardware timer function on the PCI-6602 card which would be preferable?
thanks.
(3,525 Views)
Hi Techtalker,
one solution is to use a loop with a wait block. Build array´s with your data and connect them to the loop.
Mike
(3,518 Views)
The answer will depend somewhat on what accuracy you're looking for. For instance, does the event have to happen at exactly 1 minute into the test sequence? What about 1 minute, 10 seconds? Or 1 minute, 20 seconds? If your accuracy is pretty slack then you can use a software timer. If not, then you will need to use some sort of hardware timer.
A brief overview can be found here: Timing Deterministic Applications.
(3,512 Views)
Thank you both of you.I will look into it and get back to you in a few days.
(3,478 Views)
smercurio:
The accuracy can be a bit slack. If it is off by 10 or 15 seconds, it is ok so I guess I am going for a software timer. However, could you give an idea of how to use the hardware timer when I am using the PCI-6602 card.
thanks.
(3,399 Views)
Basically this involves using the DAQmx Create Timing Source VI to create a timing source for the timed-loop. You can set the timing source to be of a set frequency and then in the loop you just need to check if you're at the required multiple of your timing frequency. There's a couple of examples of how to do this within the examples that ship with LabVIEW. Open the Example Finder (Help->Find Examples), and do a search for "timed-loop". One example is called "Digital Input Output-Frequency Source".
(3,385 Views)
