As Lynn said, I think all you need is a simple Wait(ms) call, but to answer your specific questions...
The Elapsed Time Express VI tells you if the time you specified for Elapsed Time has expired; it does not actually wait for the time to expire. An example of how you would use this is to include a call to the function in a loop. When the "Time has Elapsed" boolean is true, you perform some action. If not true, you do nothing. This would allow you to use a fast running loop that only did some elapsed time action every so often instead of every time through the loop.
The Reset you asked about is a way to reset the internal state of the VI. The VI keeps state information, which makes sense and is normally what you want it to do. However, you may want to have it
reset on this particular execution, e.g. on the first iteration of a loop that is within an outer loop.
Hope this helps,
Roy
