Urgent!! a very simple question: How to building a 2D array of strings from a text file?
Hi there Experts !!
I want to do a very simple operation in LabVIEW --> read in a text file and put the contents inside a 2D string Array !!!
I used the built-in "Read from Text File" VI, and i got all my content inside a string.
I now need to process this string and put the contents inside a 2D array.  But I don't know how.
here is the what my tab-delimited text file looks like:
content1    content2    content3    content4  ........  content9
content10  content11  ..........................................  content18
contentN   contentN+1  ......................................... contentN+8
So, I need a 2D string array of a fixed width (column number) of 9, and the height (the row number) depends on the text file.
I have tried alot of things, but all failed......
Please help with this ASAP.  Thank you very much !!
Warmest Regards,
Dave
(2,764 Views)
I just modified the Read From Spreadsheet VI to output strings. See the attached VI.
Andrew Alford
Production Test Engineering Technologist
Sustainable Energy Technologies
www.sustainableenergy.com
(2,760 Views)
Thank you very very much Andrew !!!!
cheers!!
(2,747 Views)
Use Spreadsheet String to Array (String palette). Wire a 2D string into the type input and your delimiter (the default is a tab) into the Delimiter input.
___________________
Try to take over the world!
(2,737 Views)
Hmm... for some reason I didn't see the 2 existing replies the first time around... Smiley Sad
Just ignore that last one.
___________________
(2,734 Views)
