Urgent! Stuck in execution mode (ver. 6.0)
    I was testing out the VI properties and selected "Run when Opened" as well as "Auto Handling of Menus when launched". It worked, but now it's not allowing me to get back to Edit mode. All options and menus are disabled. I can't get out of Execution mode.
I'm running Labview 6.0i (yeah, i know. It's old!), on WinXP
Vince
(3,209 Views)
Opena new VI, then place the offending VI on the diagram. Double-click its icon and it will open not running.
Message Edited by altenbach on 05-11-2007 11:05 AM
(3,207 Views)
    That worked! thanks...
is that a bug in the software? I noticed other people had this same problem...
(3,201 Views)
No, its a feature! 🙂
Just don't disable things until everything is fully debugged. 😉
(3,182 Views)
Holding control and pushing the period (.) key will also stop a running VI and place it in Edit mode.
Brian B
Account Manager
(3,142 Views)
It is easily possible to place a VI in a mode where "ctrl+." will not work, for example if you customize the menus.
Create a custom menu and remove the "operate...stop" entry. Now try to stop it as described! No go! 😮
(3,124 Views)
