Upload the data file automatically in Simulation Arbitrary Signal
How can I do that the simulation arbitrary signal upload the data file automatically?.
That it's to say , if I change the data in the .lvm file, how can i do to not upload the file in the simulate arbitrary signal properties again?
And another question, how can the signal generated continuosly? I want visualize the signal is advancing in time
Thanks.
(2,370 Views)
Hi Cristina,
simple solution: don't use both ExpressVIs, but wire the output of ReadSpreadsheetFile directly to your graph…
Why do you need to load a file, then save the data again to load the data for a second time?
(2,353 Views)
