Upgrading problems from Labview 8.5.1 to 8.6
Hi Dave,
I have installed the real time stuff from the vision 8.6 cd, and the problem isn't solved Smiley Mad
Any other sugestions?
Ad.Dekkers
Message 21 of 28
(2,440 Views)
Hey AdDekkers,
Please post your email address to the forums (you may want to s p a c e it o u t to avoid spam) and I will email you from a support account.
To all who may read this: when the issue is resolved, I will post the solution to the forums for all to have and enjoy in the future 🙂
David G
Sales Engineer - SE Michigan & N Ohio
Message 22 of 28
(2,418 Views)
Ad (dot) Dekkers (at) Thomson (dot) net
Message Edited by Support on 12-01-2008 11:42 AM
Message 23 of 28
(2,396 Views)
I need this 2 Files too
--> Volker(dot)Kupfer(at)gmail(dot)com
Thanks in advance!
Message Edited by Support on 12-01-2008 11:43 AM
Message 24 of 28
(2,375 Views)
Hello All,
As mentioned in this post, the workaround for the Preallocated.llb issue is to check the option for Real-Time support when installing the Vision Development Module.
Cheers!
David G
Message 25 of 28
(2,310 Views)
Hi Dave,
I have installed the trial of Real-Time and didn't work form me.
I guess when Real-Time is installed the Real-Time support should be installed too.
Best,
Tochko
Message 26 of 28
(2,302 Views)
Hello Tochko,
You must install Real-Time support for all versions of LabVIEW on your machine from the NI-Vision disc (not the Real-Time Module). This solution worked for AdDekkers, as well as for several test machines here at NI. Give this a shot once more, being sure to select support for all of the versions of LabVIEW on your machine. I hope this resolves your issue. Happy Thanksgiving! 🙂
David G
Message 27 of 28
(2,299 Views)
Hi Dave,
Thank you for the response. I will give it a try.
Happy Thanksgiving to you too!
Tochko
Message 28 of 28
(2,292 Views)
