Upgrading from Labview 2011
Hi all ,
i'm trying to upgrade VIs from LV2011 to a LV version that work with the OS Windows 10 .
so it's better to install LV 2015 or 2016 ?
thanks
(3,991 Views)
As a general rule, I'd say always go with the newer version of LabVIEW.  More likely to be compatible for longer.  And LV 2016 added quick drop enhancements that I now can't live without 🙂
(3,963 Views)
Yeah but i need to upgrade these VIs with less issues coz it’s not my code and there is no documentation so any suggestions please  .
who’s better in term of compatibility with LV 2011 , Lv 15 or Lv 16 ?
thanks
(3,960 Views)
To my knowledge either 2015 or 2016 has about the same likeliness of compatibility with 2011.  You should also look into the VI Analyzer Upgrade Tests.  They aren't perfect but are a pretty good indication of what (if anything) will break by upgrading.
(3,957 Views)
Go back and read BowenM's original response!  As long as you are within a few (5-6) versions difference, and there aren't compelling reasons to not upgrade to the latest version (I'm looking at you, LabVIEW 2017!), the most recent will be "the most recent", more features, (usually) better response, etc.  So if you are deciding 2015 or 2016, I strongly second BowenM's suggestion to use 2016.  Besides, it has My Favorite Feature ...
Bob "Channel Wire" Schor
(3,942 Views)
I've just upgraded several programs from 2011 to 2017 with very little issues. I did develop a small program to search for deprecated code, and it was just some Write to spreadsheet that needed changing.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,892 Views)
Can you share this VI please ?
(3,890 Views)
