Upgrading LabView from 2014 to LabVIEW 2016
I have labVIEW projects from version LabVIEW2016 but currently I have the oldest version (LabVIEW 2014 ), so I cannot open my projects. Can you help me with this, please
(1,273 Views)
Hi nalnaim,
You need to downconvert those VIs from LV2016 to LV2014 using LabVIEW2016 (or newer).
When you need help with that you should post your VIs in the VersionConversion thread!
(1,272 Views)
Thank you for your suggestions
Can you advice me how to upgrade my old version LabVIEW2014 to LabVIEW2016, please?
(1,257 Views)
You can use  https://forums.ni.com/t5/Version-Conversion/bd-p/VersionConversion for Conversion.
Make sure you are not sharing a .zip file with N Number of Individual Modules inside.
(1,232 Views)
Hi nalnaim,
Install LabVIEW2016 (and everything else you need), then activate LabVIEW using your license/serial number…
(1,224 Views)
