09-09-2006 12:03 PM
09-09-2006 12:48 PM - edited 09-09-2006 12:48 PM
Message Edited by Gonzo on 09-09-2006 12:50 PM
09-10-2006 10:59 AM
09-11-2006 06:24 AM
09-11-2006
08:25 AM
- last edited on
07-02-2025
03:46 AM
by
Content Cleaner
The latest version of DAQmx is 8.3 and that is what should have come on your LabVIEW 8.2 distribution. You could also have gotten it from here. I know that shows up in LabVIEW 8.20 as I only have the evaluation version and I installed DAQmx 8.3 after downloading it. It sounds like you may have installed 8.20 before getting the CD's. While this is a nice feature that NI has made available, the downside is that you might miss one of the other required updates.
10-05-2006 03:05 AM - edited 10-05-2006 03:05 AM
Hi
I've had a similar problem. Updated to 8.2 from 8.01, installed DAQmx8.3 (from the link given) but I just get a host of broken wires in the standard DAQmx VIs, such C:\Program Files\National Instruments\LabVIEW 8.2\vi.lib\DAQmx\create\channels.llb\DAQmx Create Channel (AO-Voltage-Basic).vi - See attached pic (hopefully).
Looks like the attach didn't work...pic would have shown many broken wires around property nodes...
Message Edited by blue_cortina on 10-05-2006 03:07 AM
10-05-2006 07:36 AM
10-05-2006 08:49 AM
10-05-2006 09:09 AM
