Upgrade from 7.0 to 7.1
We are having problems with -410 Query Interrupted errors using HP 34401A Multimeter.  We are using GPIB and receive error code -1074001665.  I read a forum response that told a user to try a patch to readmeasurement.vi.  If the patch worked, there might have been a mod to 7.0 labview.  I have not seen anything else on this.   If we upgraded to 7.1 would this fix our problem, or has there been a mod to 7.0?
(3,129 Views)
Hi BillK2,
Could you please put a link to the post you are referring to? I looked in our system and it appears this was fixed in 8.0, but again I am not exactly sure what patch you are referring to. It can't hurt to upgrade to 7.1 because it did fix a number of bugs. Let me know. Thanks!
Stephanie
(3,099 Views)
Stephanie, I was wrong the patch is in this thread.  It is read meas replacement.vi.   http://forums.ni.com/attachments/ni/170/217544/1/HP34401A%20Read%20Meas%20Replacement.vi
(3,066 Views)
Hi BillK2,
I can't tell what the bug is just from that VI. Could you post a link to the post where you found that? What I said earlier still stands though about 7.1 and 8.0. 🙂
Stephanie
(3,041 Views)
