Upgrade a legacy DAQ
I'm upgrading a system that is using a NI cDAQ-9172 with NI 9211 and 9213 modules.
From what I can tell, the modules will work with the latest LabView, but the chassis will not.  Is there an updated chassis that will work with the older modules?  Thanks in advance.
(426 Views)
https://www.ni.com/en-us/shop/model/cdaq-9178.html
The 9178 should work as long as the modules are still supported. You could also get a 3-slot chassis if you only have to modules.
(421 Views)
Thanks!  (We have 6, so the larger one is perfect)
(417 Views)
This link is useful for checking if you have not seen it before
https://www.ni.com/en/support/documentation/compatibility/21/ni-hardware-and-operating-system-compat...
(405 Views)
