Updateing Indicators and Controls
I am using LabView 5.0
In a SubVI I am using a loop and would like to update the value of an
indicator an the front panel of the calling VI before the loop is
finished and the SubVI is left. How can I do that?
If this is not possible, what are you doing in such a case?
regards
Paul Steiner
HSR Hochschule Rapperswil
Paul Steiner
Abteilung E6d
Oberseestrasse 10
CH-8640 Rapperswil
Switzerland
Tel: +41 55 222 4111 (intern 222 verlangen)
Fax: +41 55 222 4400 (z.H. Paul Steiner E6d)
EMAIL: p2steine@hsr.ch
(6,192 Views)
If you use a global variable you can write to the variable from the sub-vi
and read the variable from a loop in the calling vi.
Helge
(6,192 Views)
better still, use local variable of the indicator in question. Much faster
than a global.
Helge Lyshaug wrote in message <7jif74$ihi$1@news.uit.no>...
>Helge
(6,192 Views)
It works with a global variable, I tried it out. A local might be faster but
with a local you cannot write to the calling VI.
Paul
> than a global.
lling vi.
> >Helge
Mit freundlichen Grüssen
Paul Steiner
Paul Steiner
Abteilung E6d
Oberseestrasse 10
CH-8640 Rapperswil
Switzerland
(6,188 Views)
