Update value while typing hex display not working
When I select the property Update value while typing in string with hex display is changing the display style to normal. How to make hex display string  to Update while typing ?
(3,799 Views)
Use the DispStyle Property (hex = 3)
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(3,791 Views)
I have tried using property node also. I made display style 3 and update value while typing to true then also it is changing to Normal display. I tried those options in property right click and also using property nodes. Both not working.
(3,772 Views)
As of i see it is a labview bug. If update value while typing is not working with hex. Why such option is provided. I tried in 2009 sp1 also in 2010.
(3,770 Views)
Hi
When we create a property node "display style" for the indicator, and set its value to 3 (for hexadecimal), your indicator would display hex value while updating the value while typing.
I agree that still when you right click on the indicator, it would show normal display checked and not the hex display. This might be a bug.
But the task could be accomplished using diplay style property.
Ashutosh Singh
(3,744 Views)
No, it is not working with property node also ..
(3,734 Views)
I see the same effect. Both setting hex display and setting update value while typing work individually on either the control's properties or executing a property node. BUT setting update value while typing changes the display mode from hex to normal, and setting hex display mode turns off update value while typing (LV 2009)
I think that I did once get both hex mode and update while typing on together, but I can't now!
EDIT: To clarify; The effect is seen both on executing a property node and when using the control's right click proprety menu.
Rod.
(3,729 Views)
