Update list folder during execution
I need simple thing to my project. I would like run some VI if some file will be add to folder.
I tried create List folder function with Path control (where can I choose source folder) and Array size. But if I add some file into folder then Array size is still same. Array size is update after rerun of VI.
Some ideas how can I do that?
(2,344 Views)
You don't provide sufficient information. Do you run the "list folder" function at regular intervals on the same path or just once?
Can you attach a simplified version of your code?
(2,338 Views)
(2,333 Views)
