Update file name
Hii, Ray
     How are you doin? i just want to say hi, my project has almost come to an end, and i am appreciating the efforts of my friends, who helped me during this important project, thanks Ray.
Nishant
Message 91 of 94
(1,405 Views)
Glad to hear that it went well.
And you are welcomed.
Ray
Message 92 of 94
(1,392 Views)
Hiii, Ray
             How are you? hey, i am in somewhat doubt....
               As we are concateating the numeric number after the file name,i dont want numeric values or any of the operators or extra characters like - , or _ etc. in the file name so i want to check the string of the file name for there must be only string character into the file name string, then how should i check that? please suggest me some method for that.
Nishant
Message 93 of 94
(1,285 Views)
Hi Nishant,
Sorry, I had not noticed your question earlier...
If I understand correctly, you want the filename to be purely alpha numeric, is that correct?
Example:
Good:  filename0001.xls
Bad:    filename_0001.xls
Bad:    file-name-0001.xls
However, I'm not sure what you mean by : "i dont want numeric values or any of the operators or extra characters like - , or _ etc. in the file name"
So does that mean that the filenames do not have numeric values?
Therefore:
Bad:  filename0001.xls
If that is the case, then how would you create distinct names which are incremented?  Using letters maybe?
Can you clarify?  Also, is this for the same topic as what was discussed earlier in this thread?
Ray
Message 94 of 94
(1,269 Views)
