Upconvert VI Requests
@Sr Test Engineer wrote:
can anyone convert these files to work with Labview 2009?
That appears to be Thermotron drivers. Did you check the manufacturer's web site? They have LabVIEW 8 drivers available. http://www.thermotron.com/support/instrumentation/IVI-LabVIEW-Drivers
Message 961 of 1,261
(1,701 Views)
Yes I did but they told me I need to convert from IVI to what labview can  use
Message 962 of 1,261
(1,697 Views)
I'm sorry, but I do not understand that comment.
Message 963 of 1,261
(1,685 Views)
Could you help me convert these two VI's?
Thansk,
Source Labview: 5.1.1
Target Labview: 2009
Message 964 of 1,261
(1,661 Views)
Hi smercurio_fc, When I run ER3000 Test or ER_example.vi, I get error list saying ReadNetVar.vi, WriteNetVar.vi, Shudown.vi, Startup.vi all not executable. What's the problem? Error screenshot attached. Please help.
Message 965 of 1,261
(1,648 Views)
Hello to all,
I also have the same problem with opening old library of VI.
Can somebody can up-convert from Labview version 5.0 to 8.6 attached file?
With regards,
Matej
Message 966 of 1,261
(1,646 Views)
Hi sreeni,
it would really help to
- attach your screenshots as JPG (instead of using proprietary document formats)
- show the error for the erranous VI (instead of the main VI)...
Message 967 of 1,261
(1,644 Views)
Thansk,
Attached are in 8.2, which you can open
Message 968 of 1,261
(1,634 Views)
@MatejM wrote:
Hello to all,
With regards,
Matej
attached is in 8.2, which you can open
Message 969 of 1,261
(1,629 Views)
Do you have the DLL required by the VIs? I assumed you did. If you do, you may need to update the path to the DLL in the subVIs. Open the subVIs and find the Call Library Function Node blocks. Double-click them and provide the path to the DLL. If you do not have the DLL, go to where you got the VIs to get the DLL.
Message 970 of 1,261
(1,628 Views)
