Upconvert VI Requests
I am trying to open the attached llb for nerual network, but the version is too low to open, I am using 2010.
Is it possible to convert it here, thanks.
Message 821 of 1,261
(1,124 Views)
Kindly upconvert this VI (LV 5.1) so that I can access it on LabVIEW 2010.
Thank you in advance.
Rajshekar
Message 822 of 1,261
(1,117 Views)
Dear smercurio_fc - finally managed to track down the latest version of the LabView source (was not the version that was checked into our source control system which explains the missing/incomplete nature of previous posts).
Please find attached the full set again - could you convert to 8.5
Message 823 of 1,261
(1,101 Views)
Hello dis1
Can you please confirm which opersating sysetm these VIs were originally created in?  Thank you very much!
please upconvert following link 7.1 LV to 2010 Lv
Sincerely,
Greg S.
Message 824 of 1,261
(1,091 Views)
attached
Message 825 of 1,261
(1,085 Views)
Rajshekar
attached
Message 826 of 1,261
(1,087 Views)
ok...
Message 827 of 1,261
(1,081 Views)
Dear smercurio_fc
The uploaded all.zip still seems to think it is version 5.1.1 (and the date stamp still references 2000) - I would expect the datestamps of the files to change at conversion?
Message 828 of 1,261
(1,074 Views)
Dear smercurio_fc
The problem was that the files were marked as read-only. The mass compile has a bug - it doesn't tell you it's unable to save the files during the compilation because of the read-only bit. Very annoying. Attached is the archive saved as 8.2. Verified that the files can be opened in LV 10.
Message 829 of 1,261
(1,066 Views)
Hey I need to upconvert from Version 5.0 to version 10.0
Message 830 of 1,261
(1,060 Views)
