Upconvert VI Requests
Could anyboby covert the attached dll in LabVIEW 2009. This dll is in LabVIEW 5.1.1. Please convert it in LabVIEW 2009.
Kindly reply back with the converted dll ASAP.
RJ
Message 551 of 1,261
(1,501 Views)
Could anyone please convert the attached files in Labview 5.1 to Labview 8.5
Wanted to repair an old system which has 5.1 version vi's installed in it.
Thanks in advance.
Regards
Grugh Mike
Success is Everything !!
Message 552 of 1,261
(1,483 Views)
Hi R_J
Did you mean llb not dll? This is my first time trying upconversions, but I attempted to upconvert the three vi's. It was tricky because not all subvi's were included in the file so there are broken wires. Hope it works.
Allie
Message 553 of 1,261
(1,474 Views)
Thanks in advance.
Attached in 8.2
Message 554 of 1,261
(1,469 Views)
Could someone convert the attached VI verion 5.0.1 file to a labview version 8.5. I will be able to read it with labview 2010 right?
Thanks a lot in advance.
Message 555 of 1,261
(1,452 Views)
Could someone convert the attached VI version 5.1.1 file to a labview version i could read with LV 2009 SP1.
Drivers for Wayne Kerr Impedance Analyser 6xxx don't exist in another LV version :(.
Message 556 of 1,261
(1,431 Views)
Attached in 8.2. It uses Traditional DAQ, so you'll need that.
Message 557 of 1,261
(1,408 Views)
Attached in 8.2, which you can open.
Message 558 of 1,261
(1,407 Views)
Thank you very much
Message 559 of 1,261
(1,391 Views)
Please convert the attached two files into labview 8.5 version.
Thanks in advance.
Regards
Grugh Mike
Message 560 of 1,261
(1,370 Views)
