Upconvert VI Requests
Hi Chee
Here it is in verision 8.0, which will open in 8.6.
Best Regards
David
NISW
Message 321 of 1,261
(1,486 Views)
I would be grateful if someone could upconvert the attached files.
Thanks!
Source version: 5
Target version: 8.5
Message 322 of 1,261
(1,457 Views)
Thanks!
Source version: 5
Target version: 8.5
That appears to be a library for some DAQ device from a vendor. Unfortunately, it cannot be updated since the code uses Code Interface Nodes. You will need to contact the vendor to get an updated version.
Message 323 of 1,261
(1,448 Views)
Works great!  Thanks!
Matt
Message 324 of 1,261
(1,443 Views)
Thanks for the info and the upconvert attempt.
Message 325 of 1,261
(1,434 Views)
I'm trying to up-convert 5.1 VIs and executables to work with 8.0. We have a Labview developed test application that no longer works, due to computer upgrades and network domain changes. I was hoping to make the required changes in 8.0.  The original developer is long since left the company  😞
Thanks for any help or advise you can provide.
VI zip attached
Brian
Message 326 of 1,261
(1,426 Views)
Brian
So what is the issue? LabVIEW 8.0 can open LabVIEW 5.1 VIs directly. Once they're opened you can just save them, and they will be in 8.0.
Message 327 of 1,261
(1,421 Views)
Can anyone please convert the attached driver to a version higher than Labview 8. Thanks in advance
Message 328 of 1,261
(1,388 Views)
Hi!
I have Vi in Labview 5.1.1.
I work with 8.6
Can anyone please convert the attached driver to a version higher than Labview 8.2
Thanks in advance
Louison
Message 329 of 1,261
(1,373 Views)
Looks like you may have some missing typedefs. Please see the Mass Compile Report included in the archive.
Message 330 of 1,261
(1,356 Views)
