08-23-2010 10:06 AM
@mescaline wrote:
dear smercurio_fc
i have kepco DC power source
attachments is LabVIEW version 5.0
i need a LabVIEW version 8.5 files (espicially KepcoDCPwr Interactive Example.vi file)
would you help to me
best regards
Attached are the VIs in 8.2, which you can open. You should check IDNET to see if there's updated instrument drivers already available for your power supply model.
A couple of the VIs were looking for a VI called "KepcoDCPwr Error Message", but there was no such VI there.
08-23-2010 01:48 PM
I am posting version 5.0 Drivers for the Anritsu MS266x family spectrum analyzer. I need the drivers upgraded to Labview version 2010. They do not seem to be available in any version newer than 5.0, taken directly from Anritsu. (Which I cannot open)
Thanks very much,
Jonathan
08-23-2010 02:00 PM
Attached are in 8.2, which you can open in 2009. You can just do a mass-compile on the directory. Check the LabVIEW documentation if you don't know how to do a mass-compile. Tools -> Advanced -> Mass Compile.
09-01-2010 07:54 AM
could your help with converting this from Labview 4 drivers to Labview 2009 compatible version. Thanks.
Sergey Ivanov.
09-01-2010 08:06 AM
Here
09-01-2010 01:56 PM
I need to upgrade my LabVIEW code. I was asked to post in this thread by NI for upgrading my Labview code.
This code was written in Labview 5.1 (PC) I need it to be converted to Labview 2009 (for Mac). I was told that it first needs to be converted to 8.2.1 and then to LabVIEW 2009. I tried in 8.2.1 and seems to come up with conflicts between Traditional DAQ.
Source ----- LabVIEW 5.1 (PC)
Target ----- LabVIEW 2009 (Mac)
The main VI to open in this library is Profiler.vi
swam
09-01-2010 02:04 PM
09-01-2010 02:19 PM
When the library was created the Traditional DAQ VIs were saved with it. Also, the configuration VIs were saved with it. This was an error, since these VIs should be loaded from the LabVIEW directory. Attached is the library in 8.2 with the LabVIEW-shipped VIs removed (at least the ones I recognized). Obviously, you will need to install Traditional DAQ for this to work.
09-03-2010 11:04 AM
Could someone upconvert these Sigma Systems C-4 Controller Drivers from 5.1 to 8.2 or 8.5?
Thanksl.
09-03-2010 12:49 PM
Thanksl.
The attached is in 8.2.
