Upconvert VI Requests
Hi initech,
you asked the same question before - and you were given answers...
As your VI is LV2009, you don't need any upconvert help!
What's wrong with those answers?
Again: "what vis are missing and their function in the attached vi"
- The missing VIs are named in the search dialog coming up when opening the VI.
- Their function is (mostly) given by their name.
Search for the missing VIs in the same place where you found that "CPUTest"-VI...
Message 191 of 1,261
(1,663 Views)
Brilliant.  Thanks again smercurio, you have been very helpful.  I figured a lot of those VIs are part of the program, but uploaded them just in case.   I am looking forward to getting this thing up and running.
Message 192 of 1,261
(1,649 Views)
I need to convert from 4.0.1 to 8.5.1 of Labview.  Any help greatly appreciated.  Thanks
Message 193 of 1,261
(1,636 Views)
in 8.2...
Message 194 of 1,261
(1,632 Views)
 I am missing vis they are not on the pc (it only has the executable ) ...the vi's show up with a big ? in them and the code will not run so , NO my questions  were not answered, thanks anyway. I just wanted to determine what the missing VI's do and how to replace them with new VI's
Message 195 of 1,261
(1,602 Views)
There are some LabJack VI's missing.  So if you install the driver for that, you can find them.  The rest of the VI's all look to be homemade in a directory called Mamo.  There is no way we can help you figure out what they do.
Message 196 of 1,261
(1,602 Views)
If you need help as far as the LabJack VIs, give us the names of some of them and we will point you in the right direction.
Message 197 of 1,261
(1,594 Views)
Hi All!
I am still fairly new to LV, and have run into an issue with an older version sample VI (two actually) that were sent to my by MTI Instruments to interface their PBS-4100 balancing computer with LV.  The problem is... they are saved as v 5, but I'm using v 8.5.  Can someone please convert these for me?
Also, is there an app available to allow me to do that myself?  Sometimes I run into some sub-VIs that I like and they were created in older versions.
Any help would be greatly appreciated!  Thanks in advance.
Todd Munsell
Test Cell Manager
Wood Group Pratt & Whitney Industrial Turbine Services, LLC
Plattsburgh, NY
Message 198 of 1,261
(1,574 Views)
Hi Todd,
"Also, is there an app available to allow me to do that myself?"
Yes - use a LabVIEW7.1 as I do Smiley Wink (You have to use an older LV version to convert such VIs.)
Attached in LV7.1 - but please clean up the bigger VI on your own. Also try to use real RadioButtons instead of that subVI...
Message 199 of 1,261
(1,568 Views)
Thanks tons!  I'll give it a shot.  🙂
Todd Munsell
Test Cell Manager
Plattsburgh, NY
Message 200 of 1,261
(1,560 Views)
