Upconvert VI Requests
@RVescovi wrote:
Current Version : 5.0 (i think)
Target Version : >=8.5
What should i do next?
Thanks.
Rafael
Attached is in 8.2, which you can open.
Message 891 of 1,261
(986 Views)
Hello. Could you please convert these files from Labview 5.1 to Labview 2010?
thank you very much
Message 892 of 1,261
(976 Views)
Hello:
Can anybody upgrade attached library into the newer version of LabVIEW 2009? Please check the attachment. Also check the below links:
http://zone.ni.com/devzone/cda/epd/p/id/3552
Thank you very much for you co operation,
Vir
Message 893 of 1,261
(970 Views)
thank you very much
attached
Message 894 of 1,261
(966 Views)
@Viral Patel wrote:
Hello:
Vir
Can't. VI's were saved without a block diagram, and you cannot recompile a VI without it. The description says it was developed by VI Engineering, so I would suggest contacting them to see if they have an updated version.
Message 895 of 1,261
(965 Views)
Hey,
Could somebody please convert the allan_statistics_v2_lv711.llb from the page: http://zone.ni.com/devzone/cda/epd/p/id/502?  The file is from LV version 7.1 and I would like it to be converted to 2010 (10.0.1).  I am operating on a Windows 7 system.
THANK YOU!!!
Leif
Message 896 of 1,261
(963 Views)
@Leif Arnesen wrote:
Hey,
THANK YOU!!!
Leif
Can't. Same problem as Viral Patel's request: VIs were saved without a block diagram. Whoever at NI wrote the VIs will need to upconvert it since they would have the VIs with the block diagram. If you need the VIs then you will need to contact NI Tech Support directly.
Message 897 of 1,261
(959 Views)
thanks a lot!
Message 898 of 1,261
(955 Views)
Can someone convert this .llb file to LabVIEW 8.5 version.
Thanks in advance.
Br
Message 899 of 1,261
(928 Views)
Thanks in advance.
Br
Attached is in 8.2, which you should be able to open.
Message 900 of 1,261
(921 Views)
