Unlinked VIs when building a project
I have a build problem.  Their seems to be a problem findig some VIs when I build my application under LabVIEW 8.  Trying a mass compile before the build process does not help much.  Any Ideas ?
Error 7 occurred at ABAPI Dist Report Read Link Info Error.vi -> ABAPI Dist Cmp Settings to Disk Hier.vi -> ABAPI Get Settings From File.vi -> EBEP_Invoke_Build_Engine.vi -> EBUIP_Build_Invoke.vi -> EBUIP_Build_Invoke.vi.ProxyCaller
(2,652 Views)
The Application Builder in 8.0 was modified to look for the Help file paths for any vi within in the executable. The error occurs when some of the paths are incorrect. The Update 8.0.1 will fix incorrect help file path for some vi's in 8.0, so I would first suggest to update to 8.0.1.
Another source of the problem could be the Help files for the top-level VI. To check this, go to File»VI Properties»Documentation and verify the Help tag and Help path. Once the broken Help file path is corrected, the build should continue without the error 7.
Evrem
NI Switzerland
(2,643 Views)
