Unix to Linux
Hello
Hello
I have developped an executable based on several VI with Labview 7 on Solaris Unix envirnment .
We want to have the same executable on a linux Centos platform.
Is it portable and executable with the runtime library ?
Is there anything to move from platform to the other one ?
(3,081 Views)
Hello David,
You can find an answer in this document :
Running LabVIEW Built Executables Between Windows, macOS, and Linux OS
Have a good day
Eloise
NI France
(3,046 Views)
In case it wasn't clear from Eloise's answer, no, you cannot copy a Solaris executable to Linux and expect it to work. You can, however, rebuild your LabVIEW code for Linux, although you will have to find some version old enough to read your LabVIEW 7 code as I don't think you'll be able to open it in a modern version of LabVIEW.
(3,032 Views)
