Unitronics PLC interface DLL with LabVIEW
Dear all,
Is it possible to interface PLC, which can be interfaced with VB6 using 2 files, with LabVIEW?
1. amiCommPro.ocx (1.0.0.1   ; Allen-Martin amCommPro Control)
2. UnCmDrv1.DLL
VB6 uses these DLL and OCX files to connect to PLC via serial port.
(7,056 Views)
Hi m_min,
if you have the protocoll description you can use the VSIA functions to communicate with the PLC over serial port.
Mike
(7,054 Views)
Unitronics PLC vision seires can be interfaced with labVIEW by using Modbus FB (from unitronics side) and use serial modbus example as attached here. I couldn't remember the author(NI itself?) of this serial modbus example but i guess we owe him some thanks for this example.
(6,959 Views)
Also, if you happen to get their one of their simpler PLCs, I don't think they support Modbus, but they do have a simple ASCII protocol.
___________________
Try to take over the world!
(6,944 Views)
Hi m_min,
Please see the following article: Supported Device & Driver Plug-in List for NI-OPC Server <http://zone.ni.com/devzone/cda/tut/p/id/6417> Please let me know if that helps.
Dan Richards
Dan Richards
Certified LabVIEW Developer
(6,909 Views)
