Unit test Framework UTF Error Message "Application input terminal invalid"
Hi everybody,
I'm experiencing a rather strange behavior with the UTF:
I have created a  lvlib containing some VIs to be implemented by a student. To easily check if all the reqs are fulfilled, I have created some Unit Tests.
On my computer, everything works fine. On his computer, the following error message appears:
Both computers are running on 2013SP1f2. Though mine has more power Smiley Wink
Any known issues with the UTF on older PCs? Or more precisely asked: where does this error originate from?
Cheers
Oli
Message 1 of 13
(4,145 Views)
Oli,
in which situation does the error occur?
E.g.: Open the UTF test configuration
Modifying the UTF test configuration
Running an UTF test case
It sounds to me like an issue of Application Instances being configured in an invalid way.....
Norbert
Norbert
Expert: Geometry
Message 2 of 13
(4,131 Views)
Hi Norbert,
issue occurs having opened the lvtest file and trying to run a single test case using the "Play" Button. No editing, only having changed the computer...
Cheers
Oli
Message 3 of 13
(4,129 Views)
Any toolkits/modules involved?
Are you sure that paths are correct?
What about accessibility of VI Server on the second machine? I can imagine that VI Server must be available on the default port (3383)....
Norbert
Norbert
Expert: Geometry
Message 4 of 13
(4,126 Views)
No toolkits involved, no paths used....
Unit Tests created on this second machine (different project) do run
I've attached the library for reference
Oli
Message 5 of 13
(4,119 Views)
Oli,
your lvlib tests also create the issues on my machine.
Adding a new unit test creates some other issues stating "invalid object reference". It seems to be some kind of corruption of that lvlib....
Is it possible that we deal with different OS languages?
My machine:
Win 7, 64bit English
LV 2013 32 bit English
Norbert
Norbert
Expert: Geometry
Message 6 of 13
(4,111 Views)
So it's really a trouble maker Smiley Very Happy
Seriously, there are differeneces between the machines...
mine runs on WIN7 64bit (German ) LV32bit (English), the student's machine runs WIN7 32bit LV32bit (English)
Oli
Message 7 of 13
(4,109 Views)
Oli,
do you have the chance to test your library utf's with other German systems?
If it works there, and English systems fail.... well, that's something for a CAR....
Norbert
Norbert
Expert: Geometry
Message 8 of 13
(4,101 Views)
Norbert,
will try on another colleagues' PC. (Win7 32bit German, LV2013 SP1 f2 English)
Just to get that right: my students' PC  runs German WIN7 32bit and English LabVIEW.
Cheers
Oli
Message 9 of 13
(4,099 Views)
Oli,
that makes the assumption it could be connected to the language of the OS close to obsolete....
What about a cross-reference test: Is a utf test created on the Students PC executable on your machine?
Norbert
Norbert
Expert: Geometry
Message 10 of 13
(4,093 Views)
