Uninstalling LabVIEW2009 Evaluation for Mac OSX, etc.
I downloaded LabVIEW2009 Evaluation for Mac OSX yesterday. Installed it. Created a simple data acq VI, and tried to save it. Well, the problem is that the oldest version it can save it as is v 8.0. Our lab machine (Windows XP) runs version 7.1. So, anything I develop using this is useless.
So, I want to uninstall this and revert to 7.1 for Mac OSX that we do have a license for.
Questions:
1. How do I remove LabVIEW2009 Evaluation for Mac OSX (I am using Snow Leopard) ? I cannot find any Uninstall.sh script.
2. Will version 7.1 work on Snow Leopard ?
Message 1 of 13
(6,754 Views)
Hi m-s,
I think the information you're looking for can be found in this KB: http://digital.ni.com/public.nsf/allkb/2DD1F93E5E20B5E68625743400767FD8?OpenDocument
The file for 2009 is called uninstaller.sh.
Please note that no version of LabVIEW is currently supported on Snow Leopard.
Jeff | LabVIEW Software Engineer
Message 2 of 13
(6,730 Views)
I think I mentioned this, but there is no /Extra folder in the dmg, and there is no uninstall shell script.
I had seen the link you provided before I made that post. The proposed solution is not relevant to LabVIEW 2009 as far as I can tell.
Message Edited by m-s on 10-27-2009 10:27 AM
Message 3 of 13
(6,715 Views)
I noticed this over here as well - this is only the case with the evaluation version. I would try using a software such as the AppCleaner to remove LabVIEW: http://freemacsoft.net/AppCleaner/ .
This is not an officially supported method for removal of NI software. However, as you are not seeing the uninstall script, you could give this a try.
Vivek Nath
Machine Vision
Message 4 of 13
(6,686 Views)
Would it be possible for someone from NI support to post uninstaller.sh so that people with the evaluation version can cleanly uninstall the evaluation?
Message 5 of 13
(6,531 Views)
i dont know weather MSI BLAST will help you or not.
Just try once
Somil Gautam
Think Weird
Message 6 of 13
(6,526 Views)
MSI Blast being as its name suggest for MicroSoft Installer (MSI) I am pretty sure it won't help the OP who installed the LabVIEW evaluation version in Mac OS X.
Rolf Kalbermatter  My Blog
Message 7 of 13
(6,514 Views)
Well, you can delete the LabVIEW 2009 folder under Applications/National Instruments.
Also, you can delete the Library/Application Support/National Instruments if you want to remove all the other libraries.
Still looking into why the uninstaller is not there.
Message 8 of 13
(6,495 Views)
You can try it out.
Message 9 of 13
(6,490 Views)
That worked. Thanks.
It left a little cruft around in various places (like /Library/StartupItems, ~/Library/Preferences etc.) that I cleaned up manually. You do have to reboot the computer to unload the kernel modules.
Message 10 of 13
(6,377 Views)
