Uninstall option for LabVIEW build application
Hello All,
I want to create a Uninstaller for and LabVIEW application created in 8.5.
Please give your suggestion for how to create....
Bharathi T
Message 1 of 14
(5,203 Views)
Hi!
   In LV 7.1, when I create an installer, "setup.exe" installs the application, but can be used also to uninstall application.
   Hope this may help you!
graziano
Message 2 of 14
(5,202 Views)
This is still valid in LabVIEW 8.5, if you build an installer it will show up in the Windows program list.
Ton
My LabVIEW Ideas
Message 3 of 14
(5,190 Views)
It's showed only the application(.exe), I want uninsall the installed application which is created by LabVIEW 8.5.1 and Installed in Xp machine.
Please help....
Message 4 of 14
(5,175 Views)
Hi!
   Have you just Build an application, or created an Installer?  You have to create an installer to install application, is not the same as creating an executable!
graziano
Message 5 of 14
(5,170 Views)
I just created the Installer and Installed in Xp machine. I want to uninstall the application with out going to Add/Remove programs.
In LabVIEW is there any option avalibale to create the insataller with uninstaller option????
Message 6 of 14
(5,163 Views)
If you run the installer again, it should uninstall the application. I
think that is how it works. I am not sure if you need a separate
uninstaller for LV compiled installers.
Message 7 of 14
(5,158 Views)
Hi!
   If you like it, you can make the installer create another application, "uninstall.exe", which simply points to "setup.exe", that's the uninstaller! Smiley Happy
graziano
Message 8 of 14
(5,149 Views)
Pleas list the steps to do this... I know how to create the installer ....
Message 9 of 14
(5,144 Views)
Hi!
   ...I was only joking! You already have an uninstaller: it's the same as the installer! Why aren't you done with this?
graziano
Message 10 of 14
(5,135 Views)
