Uninstall LabVIEW but leave run-time engine and DAQmx
Hoping there is an easier way to do this, basicall we are developing software on a customers computer that we buy and will eventually ship to them. However we can't ship them LabVIEW so we make an executable and just keep the run time, DAQmx and MAX. Is there anyway to do this easier than uninstalling LabVIEW and reinstalling everything else?
Windows 7
LV2013
(2,609 Views)
Under Windows, try going to Control Panel | Programs and Features and find National Instruments Software. You might be able to select all except the run-time, DAQmx and MAX, then select uninstall. If not, then perhaps consider just making a full installer for your LabVIEW executable solution, this will clearly install only the necessary components for your code to work (if it's LabVIEW 2013).
Thoric (CLA, CLED, CTD and LabVIEW Champion)
(2,597 Views)
