Unicode and .UDL files
Hi!
I have to access many different MS Access DB with OLE ODBC.
The connection to MS Access DB it is possible with an UDL file (think about
it as a text file)
I could create it on the fly (just few lines), but It looks that orignal UDL
file are written in Unicode.
Anybody knows if there is an easy way to convert a string (I mean a LabView
string) in unicode?
Thank You , OldSmobile
(3,341 Views)
As far as I remember, the corresponding ASCII codes are the same, except that each one is two bytes long in Unicode. So, add an ASCII 0 character for each one and that's it. For example 'A' (hex 41) will be in
Unicode \0A (hex 0041). I don't know if you have to add a Unicode mark to your file ... if that's the case, write something in MS Word and save it as a Unicode Text File (and read it in LabView) in order to study the file format.
If you want more details, take a look at http://www.unicode.org/.
good luck
(3,340 Views)
"Lab Viewer" ha scritto nel messaggio
news:50650000000500000087430000-1000509150000@exchange.ni.com...
> in
> good luck
Thank you Lab Viewer! 🙂
I'm exeperimenting... I'll let you know my results.
Bye, OldSmobile
(3,340 Views)
Hey OldSmobile, did you ever get this thing working?... I am trying to do the same thing...
(2,910 Views)
