Unicode Config.Ini Files
Hi Paul, thank you for sharing this library! Great work! It can be very useful but I have a problem:
When reading a Chinese sentence containing the character 不 as in the attached text file with your example "Config Example 1.vi", I get only the part before this character. I believe it is because its hexadecimal value is 0D4E and 0D in ASCII is a carriage return.
Message 11 of 15
(2,313 Views)
Good catch.  Here's the fixed version.
Message 12 of 15
(2,282 Views)
Thank you Paul. It works now for this character, but there are other characters that cause problem, for example 开 (x005F), 上 (x0A4E) and 一 (x004E ). I guess because x0A is interpreted as line feed and x00 as null character.
Message 13 of 15
(2,253 Views)
Here is the fixed version.
Message 14 of 15
(2,216 Views)
Hi Paul,
I'm really interested in your enhanced config VIs, but unfortunately I'm running LabVIEW 2016 and I cannot open them.
Would it be possible to post a 2016 version of your VIs?
Lionel
Message 15 of 15
(1,926 Views)
